NateC15's avatar
NateC15
Friendly Neighbour
2 years ago
Amc+ Plus not working
Recently AMC+ plus was introduced as one of the theme pack options. However the channels included do not work with exception of the AMC channels. Even trying to add Shudder on its own does not work. This has been an ongoing issue for awhile now. Anyone updates in regards to this would appreciated.
  • I added amc+ theme pack which is supposed to include Shudder but I have no Shudder channel and I can not access Shudder app without a subscription and no ability to log in through TV service provider. How can I access Shudder and other content that is supposed to come with this theme pack?
    • TELUS_Support's avatar
      We've alerted our Optik team to this, and will advise when we hear of an update!
  • TELUS_Support : Any news on this one??? Already mid September and I have the exact same problem ...
    Support told me that the only way to get the other channels (Shudder, IFC and Sundance) was to go back to the old system ... what kind of solution is that?
    Nobody asked you to change our system and go to Android TV ... you call that a Revolution? What a joke!
      Our dev team is looking into this to see if it's a known issue, and we'll update here if we hear anything back!
      • 607057027's avatar
        607057027
        The problem is that it is working with the old Telus optik TV equipment, since you guys went to Android boxes, only AMC+ is available in this pack.
    • NateC15's avatar
      NateC15
      Friendly Neighbour
      The person I talked to escalated  it to someone higher up and they were supposed to reach out to me when it was fixed. Never heard back but it did get fix so I don't really have much of solution.
    • NateC15's avatar
      NateC15
      Friendly Neighbour
      No it has not. I call into support and they made a ticket but yet to hear an update.
    Hey NateC15  - Our AMC+ is actually channel 441 but I can check to see if you have the channel in your lineup. I'll send you a message here to assist.
    - Eric
    • BobArthur's avatar
      BobArthur
      Leader
      Eric - the AMC+ regular channel is 441 but the AMC+ VOD channel is 440.
        I appreciate the extra info! Internally I just searched for AMC+ and only got 441 so that's really good to know! Thank you!
        - Eric
    • NateC15's avatar
      NateC15
      Friendly Neighbour
      Sorry, that is not the issue I'm talking about. The theme pack is supposed to also have Shudder, IFC and Sundance. I can not access any of these through their respective channels or On Demand sections. If I only have access to them through 441 I am effective losing/not getting what is supposed to be included. Does not also explain why I can not also select Shudder etc. by themselves instead of doing the AMC+ theme pack.
      • Suitedpair's avatar
        Suitedpair
        I am having this same issue. I added the AMC+ theme pack which is supposed to include Shudder but I have no Shudder Chanel and I can not access shudder or AMC+ through apps. Has this issue been resolved?
  • Telus recently moved the VOD content for SHUDDER, IFC and Sundance over to channel 440 ( here in Vancouver )  joining the AMC+ VOD content.
    • NateC15's avatar
      NateC15
      Friendly Neighbour
      When I look for channel 440 on the guide it does not exist. When I first added the theme pack I had access to the AMC channels/On demand content. Shudder/IFC/Sundance channels are not in the guide and I can not watch the On demand content because it's says I'm not subscribed. It also doesn't explain why when I removed the themepack and went to add Shudder on its own that I get an error and can't add it on.
        BobArthur
        Leader
        Hey NateC15 - if you are using the same Telus Optik 4K cable box ( VIP5662W ) you have to manually add channel 440 before you gain access to it. If you have one of the newer boxes then I'm not sure what the issue is. Telus recently deleted the separate VOD channels for Sundance ( channel 435 ), IFC ( channel 436 ) and SHUDDER ( channel 444 ) and added them all onto channel 440 along with AMC+.
