how do I reset slimline remote?
mmunroe
Berzelius
Organizer
Hi !
In order to reset this remote, it needs first to be in TV mode (Press Mode until the TV led is the one lit up)
Then, press and hold OPTIONS for a minimum of 3 seconds, the LED will blink twice.
Input the code 1000, the LED will blink twice.
The remote is now back to factory settings, controling only the Telus Set top Box (in Optik mode), and is ready for programming
While you are in "optik only" mode, take the opportunity to put the Box's volume to max level (25), this will ensure proper volume is sent to your TV, and you then may select a lower volume setting on the TV (this reduces "buzzing" greatly)
Have a great day !
Yves
Member of the Telus team
Assure FFH (Internet & IPTV Tech support)
2 REPLIES 2
Berzelius
Organizer
Hi !
Have a great day !
Yves
Thanks Yves!
The reset instructions on this page failed to mention that the mode must be set to TV before doing a factory reset.
Is there some way to get this PDF updated with the correct info?
