ShadiS's profile
Advisor
171 Messages
Closed
Doesn't TELUS have business specifics roaming rate plans?
Doest TELUS have business specifics roaming rate plans?
This conversation is no longer open for comments or replies and is no longer visible to community members.
Accepted Solution
Organizer
45 Messages
Hello ShadiS,
As KittyGumDropz has mentioned in her post, those are the current available Business-specific roaming packages with the addition of the following US Roaming Packages: http://goo.gl/xEOyrp
However, if you frequently travel to USA, then the best solution would be to change your existing Rate Plan to either the Small Business SharePlan 100 or 120 that include US Roaming. You will find more details and information regarding those plans here: http://goo.gl/S1Xu0P
Please note that if you are planning to changing your rate plan and are on a contract then there will be a one-time fee of $35 per subscriber if you do it by calling 611 or going in-store. If you do it yourself online, that fee is reduced to $25.
http://goo.gl/Z8QoTb
If you are not on a contract then you are able to change your rate plan for free once a year.
Hope all that helps! :)
Top Contributors
View More
Community Stats
Loading...
Total Posts
Loading...
Total Members
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
