Pik Tv problems
John2498
All of a sudden my pik tv is constantly freezing. Has Telus done something different. It has worked great for over three years. I use an adapter to play it on my tv.
KHR
TELUS Employee
TELUS Employee
As far as I know, there were no encryption changes, but there may have been digital rights configuration changes - I'll have to check with our development team.
Unfortunately, this setup isn't officially supported, since there are so many possible configurations, and there have always been content provider restrictions on mirroring a mobile device to the TV, either wired or wirelessly.
3 REPLIES 3
KHR
TELUS Employee
TELUS Employee
Hi @John2498
What kind of device/adapter are you using? The last app update for the Android mobile app was in late February and for iOS was 2 weeks ago.
Hi KHR
I’m using iOS either my tablet or iPhone then a lightning/HDMI adapter to display on my Samsung tv. Did the last update change the encryption or something?
Sent from my iPhone
On Apr 27, 2021, at 08:23, TELUSsa Neighbourhoods <TELUSNEIGHBOURHOOD> wrote:
Hi John2498,
KHR (TELUS Employee) mentioned you in a post! Join the conversation below:
Re: Pik Tv problems
Hi @John2498
Reply | Accept as Solution | Give Kudos
TELUS Neighbourhood sent this message to
You are receiving this email because you were @mentioned.To control which emails we send you please go to, manage your subscription &amp; notification settings or unsubscribe.</TELUSNEIGHBOURHOOD>
KHR
TELUS Employee
TELUS Employee
