Pik TV - blank screen, won't launch
Reply
cousinjunior
Advisor
personally, I doubt it's the box because I have had 2 brand new boxes now, and both did the exact same thing
the odds are tiny that both somehow have/had the same hardware problem, so I'll bet it's an app issue
the fix, to get past the black screen (with Android error) at bootup, is described above
and yes, approximately 1 in 25 times for me, it actually boots up without the error
cousinjunior
Advisor
possibly fixed ???
for the past 2 weeks (approximately from Dec 26th on), this problem seems to have suddenly resolved itself
it does not appear that the Pik TV app has been updated recently
I did nothing at all to my Pik settings
HOWEVER, I plugged in a small DAC into the Pik TV box so I could output 2-channel stereo sound to my stereo system
this DAC unit was plugged in/out several times, and I do not normally leave it plugged in
the DAC was plugged into the optical sound jack (TOSLINK) of the PikTV box, and also, its power supply cable was plugged into the USB port of the Pik TV box
is it possible that plugging this device into the Pik TV box somehow fixed the issue?
Just a coincidence as the actual problem is a software issue with the apk.
cousinjunior
Advisor
yeah, I figured it was just a coincidence, however I'm pretty thrilled that it's finally working correctly -- at least for now!
RE: "as the actual problem with a software issue with the apk...."
can you please clarify... what is "the apk"?
thanks
When you see apps just lingo APK (Android package) is just the file format for the android OS.
cousinjunior
Advisor
UPDATE: it's approx. 3 weeks now that my system is finally running properly... no more Android error every time I start up Pik TV!
wish I knew how it was fixed though....
retrogrouch
Connector
Had the pik box for a week now & like everyone else it's a total fail. Do not recommend.
Sound but no picture from the first login. Not sure how I got the picture to work eventually the first time as I was just mashing keys on the remote. Since finding this thread I have tried every suggestion. What works eventually is leaving it unplugged for 12 hours or more. Then multiple login attempts, reboots, cache clears etc. Fun, right?
Not user friendly, what's next, programming in basic using only the remote?
I had the pik box so confused/corrupted it wouldn't let me finish signing in before giving me an error message that I would have to select ok or exit & then attempt to sign in again, having lost all my precious digits I already entered. Finally unplugged it & left it for a few hours & it worked first try after that fiasco.
I left it on overnight after I got it working yesterday thinking I could watch today from the get go but no, it still crashed. Sound but no picture.
How many times should pik update? Only had one so far in a week.
If I stay on one channel too long it goes into sleep mode w/a nice screen saver picture. Hitting ok brings back the picture/sound. Normal?
Is yours still working?
Is the DAC worth it?
I would like to run sound through my stereo but really don't want to spend one dime more on something that works barely half the time.
y1007
Resident
OMG. I'm having exactly the same problem now!! But I've never opened this app successfully........
I found that I can't open it from my phone and browser as well. But I can use it in my office(with internet from Shaw)....Is it the problem of the internet????
