what is the correct remote code for the vizio sound bar vsb200 3273 does not work
Reply
bctjoe
Not all devices are supported on the remotes. The less common the brand name, the less likely it'll work. If you cannot find the code for it in the PDF (it's not there either way), and the Other code doesn't work, it is officially unsupported.
