can a wi-fi tv box be connected with ethernet cable
Rayandlise
I have 2 optik tv boxes, the first is hard-wired to the modem/router
it never, ever has problems with tv reception
the other tv box is connected to the modem via wi-fi
and keeps dropping the multicast signal and "initializing"
over and over, sometimes every minute
since wi-fi extenders don't help i wanted to
just run ethernet cable from the modem to it.
Or does a tech have to come out to run a special install
will it be trying to receive both by wifi and ethernet cable at the same time?
if so how would i disconnect its wifi reception
0 REPLIES 0
