What is going on with the TV guide it keeps changing and I DO NO LONGER know what channels that I ge
ch9644
TelusTech
Easy fix,
on the remote:
click 'guide'
click 'options'
select favourites list
select subscribed
now the guide only shows you what your subscribed to, alternativley if you want to see everything than de select this feature.
1 REPLY 1
TelusTech
Easy fix,
on the remote:
click 'guide'
click 'options'
select subscribed
