07-21-2017 01:56 PM
Hi,
I have been putting up with my Optik TV in the living room of my apartment not working as I usually am watching Netflix or something else. But I realized I am paying for it and still on contract so it should work.
My main box is in my bedroom (PVR) and there is a Cisco router/bridge that serves the signal to the wireless Optik TV box in my living room.
Many mornings I turn that TV on only to see the screen saying need to connect the box to the router etc... basically no connection. It isn't a long distance, but there are cement walls in my apartment. It will sometimes have a connection and then later no connection and this continues.
The system I have is maybe 2 years old now, are the newer ones that support the 4K any better for the wireless part? I will likely call in to Telus when I have time but wanted to check with others who may have the same issue.
Thanks,
Dan.
07-21-2017 05:58 PM
Cement walls are a problem for Wi-Fi in many instances. What sort of quality do you see when it is working? Do you have picture loss, etc?
Is there any opportunity to run a wire between the two, or move the Telus gateway to a more central location where a signal is better?
07-21-2017 07:09 PM
Thanks for reply. Nope if there was a way to wire them easily I would have done that and skipped wifi from the beginning.
I have other Wifi devices in the same room that work fine using my own better router. The Cisco device isn't very powerful.
07-21-2017 07:29 PM
A top quality router may properly address the multicast properties necessary to transmit the Optik Signal. Have you tried substituting your router for theirs for the Wi-Fi transmission to your TV?
