Sound on Crave and Recorded Shows
Moi
While watching recorded shows or Crave the sound sometimes cuts in and out. Rewinding the show, the sounds cuts out in the same place. Sound comes on and off throughout the show, but if we pick a different show to watch the sound is back to normal. Once the sound starts to cut out we can’t get through the show we’re trying to watch with full sound. Any recommendations?!
1 REPLY 1
Chicnstu
Leader
Could be an issue with the feed from the On Demand servers. If you list a specific show/episode and the timestamp of when the audio issue occurs some of us here could check to see if it's happening for us as well. If it's not impacting others then it's most likely an issue with your audio setup or the tv box is losing data packets received from the modem due to wiring or wireless connectivity issues.
