Replacement optik tv remote
Reply
Highlighted
Resident
Hi how do I go about reordering a replacement remote as a number of the buttons are sticking or intermittently not working
Accepted Solutions
Highlighted
Most Helpful
Community Manager
Community Manager
Hey everyone, sorry for bumping an old thread.
We now have a better solution! It is available here - https://www.telus.com/en/bc/support/article/purchase-an-additional-or-replacement-remote
All Replies
Highlighted
CPU Alum
CPU Alum
If you don't get answer, consider a harmony remote.
Highlighted
Connector
Just give Telus a call, a frient of mine had the same issue, they sent out a new one to her.
Highlighted
Ambassador
Yes, you need to contact the technical support department either by calling 310-6988 or Online at: www.telus.com/chat
Technical Support is available 24/7 and can assist you with getting a replacement remote.
Highlighted
Friendly Neighbour
i found a remote that works great for any type of ir protocol the urc-a6
i have many types of devices and it can br programmed tor all of them through the learning process for individual keys if it has not been preprogrammed for the device and it is cheap
Highlighted
Most Helpful
Community Manager
Community Manager
Highlighted
TELUS Employee
TELUS Employee
Highlighted
Resident
hi. I have a problem with my Telus remote control (as buttons are sticky). Can I replace it with a new one?
Best
Tom
Highlighted
Yup!  See PSL's post from April in this thread.
