Netflix no surround sound option on IPV5050 wireless box
Benny280
Anyone else have this issue? The 5.1 option comes up on the 4K PVR unit but not on my wireless HD box (IPV5050) that one only has stereo options available. The tv channels work fine in surround sounds, only netflix doesn't. I've checked with support and have the most up to date firmware but to no avail. Any ideas? Thanks!
I believe it's a limitation on the Netflix app on the non-4K boxes.
1 REPLY 1
