I have been using iPad for tv smart remote for several months. Now the guide is not working anymore
katarina
Berzelius
Connector
an incompatibility issue has been discovered with the latest version of the Smart Remote app (updated last week if i'm not mistaken) :
the latest version is not compatible with : 1st generation iPad, with iOS 5.1.1
The root cause of the issue has been found, and a fixed version is currently being tested and submited to Apple for approval and release through the appstore.
Yves
Member of the Telus team
Assure FFH (Internet & IPTV Tech support)
1 REPLY 1
Berzelius
Connector
Yves
