I have a Bose Cinemate Digital home Theater speaker system that won't program to the aux mode (#67)
rogo2303
The slimline remote will not accept the numerical code 67. I'm using mode 'aux' everything flows well but it will not turn off my Bose Cinemate sound system at the end. When I press the power button in the last step, the yellow light blinks twice slowly then three more times quickly but does not turn the sound stater off. (It is pointing at the sensor on the Bose system in the last step).
1 REPLY 1
Hippo
Leader
Hi, there.
The Slimline remote is not guaranteed to work with all devices. You can find further troubleshooting steps listed Online: http://www.telus.com/get-help/tv/topic.do
You may also want to try a different code http://www.telus.com/content/help/common/pdf/slimline_remote_control/AUX_Device_Insert_-_FINAL.pdf
