01-12-2018 03:08 PM
Hi,
I have the new telus remote. What code works with this tv? I got it to power up and down with the telus remote, but the volume will not work.
Thanks
01-12-2018 04:22 PM
Hello,
I don't believe the Ruwido 2 remote has codes for a Roku TV. You may need to use both the Telus remote and the remote that came with the Roku TV. Here's the page to program remotes - https://www.telus.com/en/ab/support/article/program-slimline-remote-2 You can always try code 0029 and it will go through all the codes to see if any matches your TV. The whole process can take up to 30 min.
01-12-2018 04:41 PM
For Hisense TVs you can try code - 1429
