Harmony 350 remote/guide scrolling
Reply
Highlighted
Connector
Hope u can help.
i have a harmony 350 remote. I can bring up the Optik TV guide, and  scroll through channel by channel. i am assuming the arrow buttons to the left of the "guide" button is meant to scroll the guide page by page, but it does not do this.
what am i missing
thnx all
Accepted Solutions
Highlighted
Most Helpful
Been a while since I used a harmony but you can use the learn IR to function as you want then upload to the remote. (Make sure in Optik mode)
https://support.myharmony.com/en-us/teach-harmony-a-missing-command
I assume you tried the other remote profiles.
All Replies
Highlighted
Have you tried the channel up and down button? As long as you configured the harmony correctly it should have retained the exact functions.
Highlighted
Connector
Thx for the reply. Channel up/down, while the guide is open, scrolls through one channel at a time. The Optik TV remote allows me to scroll a full page, as well as one channel at a time.
Highlighted
Most Helpful
