Freezing problems with PVR
RobHartwell
tv freezes when watching recorded shows and stalls for 5 seconds re-starts and then freezes again
Parrot
Advocate
Hi Rob.  How many boxes do you have? Are you watching the recorded shows in the PVR (CIS430) or the CIS330 box? If you have more than one box, test access to the recorded shows on the other box. You can also try doing a sequence reboot starting with the PVR > CIS330.
2 REPLIES 2
Parrot
Advocate
I am having exactly the same problem. I have one 1 PVR with 2 client units. The stuttering problem is happening to only the one of the client units. This seems to be a recent problem. That Client unit used to work fine when watching recording shows.
