02-24-2016 01:37 AM
02-24-2016 02:19 AM
As has been discussed here on the forums before, you cannot change inputs with the Slimline 2 remote. Either use the remote that came with your TV or go over to the TV and hit the Input/Source button.
02-24-2016 02:19 AM
02-24-2016 01:36 PM - edited 07-26-2016 11:18 PM
03-04-2018 02:29 PM
07-06-2016 08:34 PM
07-26-2016 10:45 PM
09-16-2016 08:30 PM
I totally agree. . . from good design to worst ever!!!!!!!
07-06-2016 08:37 PM
07-07-2016 01:43 AM
That's why a lot of people have invested in a Harmony remote setup. I can control anything I want with the same remote.
12-16-2017 12:45 AM
I just switched from Shaw to Telus. Out of principal, I think I'm going to switch back to Shaw. I can't believe they left out the input key. That is 100000000000 times worse than Apple taking out the audio jack. Telus, you aren't Apple, give us bak the f'n input key.
12-16-2017 11:11 AM
Do you have a Search button under the 7 button? This Search button has a secondary use which enables you to switch sources. To use it you first have to switch the mode of the remote to control the TV using the button at the top left. After you've done this pressing the Search button will allow you to switch inputs on your TV.
I have a slimline remote but not sure if it's a Slimline 2.
12-16-2017 11:21 AM
Slimline 2 has the Play / Pause etc in the upper half of the remote, while the Slimline has them in the lower half.
See further info here.
03-04-2018 02:30 PM
04-04-2018 12:23 AM
