05-22-2014 03:44 AM
how do i get into my account i cant remember my originak email or password and i am getting frustrated with this site
05-22-2014 10:27 AM - edited 05-22-2014 10:01 PM
Contact Telus directly. I suggest by telephone so you can describe the information you will need to prove your identity.
EDIT: The above assumes you are trying to login to you mobility account.
05-22-2014 02:09 PM
Hello-nadiaguterres-welcome: Forgot E-mail address and password, aren't you.Try to create a new account it may works
Click the link to acces Telus site: http://www.telus.com. Once logged in - on the screen displayed, click "Log in" in 2nd screen, Select the line "or Register a new account" + click it will display all the fields to filled up.
Is better use a different, E-mail address if enter the same, system may remember n' warns you the address already exist. Same applies to passwords, must be at least, 8-characters. Find cool passwords in this 'Random generator password' site: http://www.techzoom.net- once created a new acct, tested if it works. If not contact TELUS-Support at *611 or by chat.
Note: if links no open by left-click try right-click+open. <ReadMe-soon> "v9"
