05-24-2013 04:47 PM
Hello people!!!!!
How can I track my data usage per day?
Thank you
Evgueni Fedine
05-28-2013 12:03 PM
I use the TELUS app to keep track of tmy data for me. I had the same problem before, but TELUS can only see the amount of data that’s used, not where you’re going; it’s considered private information. Think of it like a gas station, the gas station has no idea where you drove or what used all your gas; that’s none of their business.
06-11-2013 11:42 PM
05-28-2013 12:03 PM
06-11-2013 11:42 PM
Use Onavo Data Counter. It can help you see what's using your data
06-17-2013 07:59 PM
Hi all,
the TELUS app is really a good app if you're after your usage for all 3 services: voice, text and data. But of course there are apps you can download specific for your device and they're FOR FREE:
For Iphones: Data Usage Monitor
For Androids: My Data Manager
For blackberry: Data Monitor App
Just go to your Apps Store and odwnlaod. It would eat up a minimal data while downloading but it wont consume any data anymore when already installed. You gotta synchronise it w/ your billing cycle , and w/ the total amount of data allowed in your plan... these apps provide real time info, some even sets alarms prior to oging over to prevent billshock...
Hope this helps
