Need help
TiaraScully
I put a prepaid card on my phone of 2 10$ ones and my plan isn't working
2 REPLIES 2
You need to contact Telus directly. Try the contact info available on the bottom of the Telus.com page.
Artemis
Ambassador
Did you purchase a feature?
It is common for people to add funds to the account and then have the account quickly drained because they are using Pay Per Use data, texts, etc as there is no feature provisioned.
As NFtoBC mentioned your best bet is to contact somebody at TELUS to review your account with you.
