Would my phone work with Telus
NASIM
HI, I AM PLANNING TO GET A PREPAID LINE FROM TELUS. I WILL BUY MY OWN PHONE WHICH IS MOTOROLA MOTO E4. i WOULD LIKE TO  KNOW IF THIS PHONE WILL WORK WITH TELUS. THE PHONE FEATURE SAYS IT WORKS WITH "GSM 850/900/1800/1900 MHz, WCDMA 850/900/1700/1900/2100 MHz, LTE FDD Band 1/2/4/5/7/8/12/13/17/25/26/66.
3 REPLIES 3
It should. You can confirm at www.willmyphonework.net
Also, you should see if you can fix the broken CAPS LOCK key on your keyboard.
NASIM
Thank you for your help. But I don't see the model I mentioned in the link that you provided.
Hi @NA SIM
You can also visit: http://mobility.telus.com/en/index.shtml?ref=http://mobility.telus.com/en/ON/phones-and-devices/devi... and enter your IMEI to check it's compatibility
