S6 Edge+
Handsomeassasin
I want an S6 Edge+ & was looking at one in the telus store but when ordering one online or on the phone with Telus they r trying to tell me they do not have such a phone?? I am not sure what is going on but I held the S6+ in my hands at the store so I kno they do exist but they are very adamant that they do not have them, why would that be,I am very confused???
3 REPLIES 3
xl
CPU Alum
CPU Alum
To clarify.... which Telus store did you see the S6 Edge+?
Apparently Google says they'll likely carry it at some point. They have a support page up for it. For personal plans, it doesn't appear available direct but it is for business ones, unless you go thru WorstBuy.
It may be old stock left at a few locations. Grab it from the location where you found it.
BTW, Bell and Rogers do not list it either.
