08-02-2018 01:02 PM
I haven't left the house yet the phone is showing the Roaming symbol. Is this costing me money?
08-02-2018 06:13 PM
Only if you use your phone!
You may be roaming because a signal from a US tower is stronger than the Canadian one. You can change the cellular settings in your phone to connect only to Telus, rather than connecting automatically to the strongest signal.
08-02-2018 06:13 PM
08-02-2018 06:54 PM
Does it say TELUS EXT on it? If it's specifically that, then you're ok.
