Phones
Reply
Ryley
Hello I see that if you have
an old phone you can bring it
in and get store credit. My
concern was can I bring in a
iphone 3 and Samsung galaxy
ace even if they still turn
on but cracked or charger input broken.
And if I did how much store credit would I have..?
Accepted Solutions
Most Helpful
There is a widget thingy here.
All Replies
Most Helpful
SuperFred
Moderator
Moderator
Hi, the website's information will help you and you can also contact your local Telus dealer here http://www.telus.com/forms/stores/en/find-a-store.jsp?cmp=mobility since they'll be the ones taking the phone, they'll be able tyo give you the details and what happens if a device is broken.
