Note 4 Marshmallow Update
Reply
6mon
GUYS!
I think I just bricked my phone trying to get the update with Smart Switch!!
I advise you wait or try another method!
6mon
Ok, scratch the last message, guys!
I had to do an emergency restore (WTF?) twice (seriously WTF??) but now it's optimizing apps in 6.0 so I think I'm all good.
That was unpleasant...
You can edit your messages using the drop-down caret located at the upper right corner of your post.
tapin4par
Downloading 6.0.1 on my Note 4. Fingers crossed...
Flowrider
Mine updated to 6 just after midnight Pacific standard time. Finally!
Isaac07
I just checked and I haven't received the Marshmallow update yet for my Note 4.  My phone was originally with Rogers and it was unlocked by them prior to moving to Telus.  Any idea if I need to do something special to get the Telus Marshmallow update onto my Note 4?
Zaptor99
Connector
In your case, Rogers will push the update. It's scheduled for may 30. http://communityforums.rogers.com/t5/forums/forumtopicpage/board-id/OSUpgrades/thread-id/1
Norwegian
So I updated today and now I don't have contacts, it's apparently updating to my new language preferences which I didn't change, I cant see a dial screen for my phone but I can answer calls, and I'm really frustrated. And my battery is draining super fast. Help!
JohnnyK
Helpful Neighbour
Any new updates for Android 6.0.1 on Samsung Galaxy Note 4? Activesync stopped working after I updated my phone to 6.0.1  😞
JohnnyK
Helpful Neighbour
Any thoughts how to fix the activesync issue on Android 6.0.1 on Note 4? I updated my phone few weeks ago and activesync stopped working as a result couldn't access my corporate email.... I saw that some users have the same issue but I couldn't find the resolution of this issue
You've asked the same question multiple times. You will need to deal with Samsung for any problems with the software. Their bugs delayed the release and if active sync isn't working, it appears they missed one.
Frich
The Marshmallow update has turned my Note 4 from a decent phone to a slow, frustrating piece of junk.
It freezes if I'm writing a text as another one comes in, then pastes whatever I typed during the freeze muliple times. It frequently restarts without any reason. It suffers sudden battery drains. Performance is generally slow and unresponsive.
I have tried clearing the cache etc. and even resorted to a complete factory reset, but nothing helps
Does anyone else have the same problems, and is there a way to fix them?
mkendrick
After I updated to 6.0.1 my note 4 gps is not working and it will lockup and reboot twice a month. Other than that everything works well.
ProzzacIsBestBand
Connector
I haven't had issues with texting on mine.
I've had lots of issues with it restarting though and it's very strange. It doesn't even seem like a full restart. I notice it when I'm listening to music, and the song doesn't even stop playing, it just sort of skips a few times.
When I notice it happening I'll look at my phone, I won't be able to view anything on the screen, and eventually I'll see the "device has restarted" message asking me to input my backup password since it won't accept a fingerprint after the restart (all while continuing to play the song I was listening to).
JohnnyK
Helpful Neighbour
After having many issues with Android 6.0.1 on my note 4, I decided to factory reset it and set it up as a new phone. It took longer time but it seems that my phone is now stable and most of the issues that I faced before the rest are now fixed. Not ideal but it worked
JohnnyK
Helpful Neighbour
