04-10-2014 03:55 AM - edited 04-10-2014 04:28 AM
I purchased a Huawei LTE B593 Telus Smart Hub on ebay. The firmware was originally V100R003C464SP058.
I had it flashed to unlock the antenna features. The new firmware is V100R001C82SP055. I now need to
upgrade back to the Telus firmware. Can anyone tell me where I can get the firmware download V100R003C464SP058 ?
I have tried restoring to the factory settings and had no success.
04-10-2014 09:48 PM
04-10-2014 09:48 PM
Your best bet is the Huawei website.
04-14-2014 11:45 AM
Hi, you can also try to do a google search, maybe you'll find some information but it will most likely send you back to their website.
12-10-2014 05:56 AM
Hi pal,
Sorry I am bothering you with this, but, I am in need for the V100R001C82SP055 file. I don't know if you get it at last the one that you was looking for, but I beg you to share with me the aforementioned one.
Thanks in advance.
