Compatible unlocked phone? Huawei Honor 6X from US
kmiles
Organizer
I apologize for bothering you folk but my Nokia 820 (Win10) is restarting constantly and I can get a US unlocked phone. Considering the Huawei Honor 6X and it uses the same nano-SIM as 820.
Here are the Honor 6X's frequency specs - will this be fully or only partially compatible with Telus. Love Telus and will reconsider purchasing other phone if not compatible. Many thanks for your help.
Huawei Honor 6X specs:
Data Transmission Type: EDGE, GPRS, HSDPA, HSPA+, HSUPA, LTE
Wireless Compatibility: Bluetooth, Wireless B, Wireless G, Wireless N
Network Type: GSM
4G LTE Band
12, 2, 20, 4, 5
GSM 2G Frequency
1800, 1900, 850, 900
GSM 3G Frequency
1700, 1900, 2100, 850
Have a look at this link for more detailed information about phone compatibility.  Usually, when dealing with phones sold to the US market, ask if the phone will work with AT&T. If so, it will also work on Telus frequencies.
4 REPLIES 4
Thanks
Here is the Honor 6X’s US Carrier Compatibility
AT&T, Go-Phone, Net10, Simple Mobile, T-Mobile, TRACFONE
So this will also work with Telus’ LTE since it covers Band 4 which Telus uses?
Keith
If it'll work in the USA, it'll work in Canada. The phone should be fine. I just needs to be the US version of the phone, not the international one.
Thanks so much - Yes it's coming from BestBuy US so it's a US configured device.
Really appreciate your help and confirmation for my upcoming Black Friday purchase.
K
