04-30-2014 03:01 PM
04-30-2014 07:58 PM
Hello-'Lalala" Let's get straight forward with this. You don't want to display Ur Ph# when make a call, aren't you. 1way is to purchase a restricted, call display "add-on" it cost $8.00 - maybe more with prices changes, who knows. 2nd depend what type of Ph Do U've is variable.
The samsungs [setting to display or not Your Ph#]. Works this way: Go to main Screen >tap Apps >settings >My device >Tap the ph.green icon >scrolldown to additional settings > new screen shows -caller ID >offer 3.options: 1) Network default,Telus in this case 2)Hide Ph#. 3)Show Ph#: So in resume, you can tick any of the 3choices at Ur own risk. In any case you can rollback the changes to default status. That's all.. Chao!! "v9"
04-30-2014 08:17 PM
Hi-again "lalala" just quickly I forgot to tell you that, your question It's been posted twice. Becareful when you, click the "Post-button" make sure you don't send double thread. The administrators or whoever overseen this software it got be a way to delete double post Asap. Thks for your attention to this matter. "v9"
