03-30-2018 08:11 PM
03-30-2018 08:17 PM
Reset your gateway / router using he pinhole on the back, and you should be able to login using the information on the label on the gateway.
03-30-2018 08:29 PM
03-30-2018 08:33 PM
What device are you using to connect to the Telus Router? The error you are experiencing sounds nor like a hardware issue with that device than the Telus device.
03-30-2018 08:35 PM - edited 03-30-2018 08:39 PM
03-31-2018 01:11 AM - edited 03-31-2018 01:16 AM
You should not be reaching that page as an error if your router is at fault. Seems like the error is further downstream than your Wi-Fi connection. If your router was not working, you could not connect to gstatic.com. I can’t reach that page at all. I get an error saying the server does not exist.
Are you certain your internet connection is live?
