Remote switch Building needs repair
brulyn
Your Remote Switch Building at Cowichan Bay Road and Glen Road in Cowichan Bay requires a minor repair.
Feral cats and other animals enter under the rear of the building which attracts our small dog and getting her to come out is very difficult with surrounding high fencing.
The installation of approximately 2 - 1" by 6" by 6' boards would block entry and solve the problem.
I would be happy to fix the problem if given access (key to the lock on the gate) for 15 minutes.
We would appreciate contact by central office personnel about this problem.
WestCoasterBC
Please remove your personal information as it’s a public forum for your security.
@dru @RhoLee can you alert the appropriate department.
3 REPLIES 3
WestCoasterBC
Thanks,
I do not know how to edit my blog.
The little caret ( v ) at the top right hand corner of your post has an option to edit it.
