06-10-2018 04:56 PM - edited 06-10-2018 04:58 PM
Hi guys ,
In the last 2 days I couldn't connect to the internet on actiontec T3200M
Both lights are green.
When I try to connect my phone I get this error :
The webpage at http://connectivitycheck.gstatic.com/generate_2 could not be loaded because :
net::ERR_CONNECTION_RESET
I tried to restart and i get the same issue.
06-10-2018 05:38 PM - edited 06-10-2018 05:38 PM
Two days? Have you called technical support in that time?
The error message you see is just a generic connection error from Chrome. It does not mean there is specifically a modem problem. A problem with your phone can easily cause that message to appear also.
Is it just your phone that is unable to connect or ALL devices in the house? (Optik TV, computers, consoles, tablets, other phones, etc.)
06-10-2018 07:57 PM
Thank you for helping !
All devices.
I don't know if I can call them.I'm in a rented apartment and I don't have any bill to get the account number.
I tried those steps but it only tells me to restart...and it does't work.
06-10-2018 08:17 PM
I'd still call anyways. Just explain your situation. If you have physical access to the modem they should be able to walk you through some additional troubleshooting.
