Home Phone
Zax
A readily and easily installed unit that can be put on the phone system that only allows pre-programed numbers to be accepted to protect the elderly and general customers from all of these phone scams.
Have a look at Telus Call Control, and see if that meets your needs. If not, it can be accomplished with a VoIP service as an intermediary.
1 REPLY 1
