High Data Usage
Reply
YouNoIt
Coach
Since i see Telus so called techs don't seem to care about the insane data usage and other problems that were never had on ShawCable .THe phone call i had with Telus tech that if the data usage is not found in a week i will go back to ShawCable
People were willing to help you but you just refused to provide any information. Your original first post about the service was well worded and highly detailed but your responses in this discussion were unfortunately not. Best of luck out there.
valiaig
Advocate
Dude actuallty 150/150 and 300/300 Mbit plans have unlimited usage Smiley Happy
YouNoIt
Coach
You are silly that is your only copy and past you have .
Nov 27 2018
Telus page
47.9 GB / Unlimited
telus site.JPGThat is from today
I average 5 GB a day maybe
I only have 2 networks one on the telus router i have my cell phone it and my security panel and no cameras .
The other network is on port 1 bridged that has my pfsense router on it and there is today's usage .
I don't leave my pfsense on at night it is turned off with the switches .
I will install bandwidth on pfsense and it will record all daily usage .
I still want to know where the usage is because it is not on my network i use for internet .
rc
Ambassador
What does the TELUS router show for data usage?
Also what does your account on TELUS.com show for data usage?
The TELUS.com usage statistics will show what TELUS will use for billing purposes, and will exclude optik TV data.
YouNoIt
Coach
telus router.PNGtelus site now.JPGSo i do not get the usage at all .
rc
Ambassador
Without knowing the time period between the router reset and the start of you billing period it is hard to comment.  What can cause confusion is that OPTIK TV traffic is multicast and excluded from TELUS.com usage data.
Without knowing how many days the 92GB covers it is hard determine your daily averages
Interesting that WAN Rx, LAN#1 Rx, LAN#2 Tx LAN#3 Tx, and WiFi-2.4G are all the same number of GB - 2,097,152, and that the number of packets don't follow the same pattern.  Looks like a lot of traffic passing your WAN / LAN interface.
YouNoIt
Coach
Now that tells me there is a problem with telus router port 1 is suppose to be bridged and 2 & 3 are 4k pvr and one digital box .There router has a problem because my router or hp server made into router does not show that activity !!
YouNoIt
Coach
pfsense.JPGThis is from all day on my network port 1
rc
Ambassador
Before doing any traffic analysis I would suggest you look at how pfsense is handling multicast traffic (iP TV traffic ).  Pfsense should not be forwarding this traffic, unless some downstream device has requested access  to a stream and igmp is enabled.
From looking at the pfsense interface stats, almost all the traffic hitting it's WAN port is being forwarded to it's LAN port,  so the question is what is the traffic and if unwanted why is pfsense firewall etc  not blocking  it.
YouNoIt
Coach
The pfsense box is on port 1 of of the useless Telus router and has it's own ip .I am calling Telus to see what they are are going to do with this horrible fibre internet and tv or going back to shaw where i had only a couple of problems and that was found after removing shaws hardware found loose and not pressed F-connectors which was causing the problems i had .
rc
Ambassador
Based your comment about the router having it's own IP, it is obvious that you do not understand the difference between routing and bridging protocols and have made some bad assumptions on how things work.
Also, based on the tone of your posts I don't think you are interested in understanding.
