04-05-2019 09:38 PM
Hi everyone,
So I seem to be struggling with link speed on my Raspberry Pi hardwired (or via wireless) and one thing that has been said frequently was to ensure flow control is enabled in the router.
I have things set up so that my Actiontec is located in my bedroom, and Telus ran a cable to connect it to a hardwired lan port in my living room where all my devices lie (if I could do it again, I would have the router placed in the living room, but so be it!)
I'm able to get full speed (300/300 connection) on everything BUT my 3B+ for downloads, uploads it's not an issue.
Is there a setting that might relate to this that I can use to see if that helps?
Thanks in advance!
