Connect Smart Light Bulb to Telus WiFi Network
Reply
TSPortMoody1
Friendly Neighbour
I purchased a smart bulb that will only connect to 2.4ghz network- how do I get my Telus Actiontec modem to manually switch from 5ghz to 2.4 so I can connect bulb?
Disable SmartSteering in the wifi settings on the Actiontec. That will create two networks. One 2.4 and one 5GHz.
If you find a post useful, please give the author a "Like" or mark as an accepted solution if it solves your trouble. Smiley Happy
TSPortMoody1
Friendly Neighbour
Do the network passwords remain the same if I split two networks 2.4 and 5
You can set a password for each. You can have them the same if you like. Just use slightly different network names so you can tell which is the 2.4 vs 5.
