telus optic with MacBook latency dropped wifi issues
chillyvanilla
hi all,
my wifi keeps dropping (wifi bars showing 4, but when i complete a search says Im not connected), and when i do a speed test it tells me that i have a latency issues? anyone else getting this?
1 REPLY 1
I'm not.  What is the ping and the speed you are seeing?
Have you looked at the band steering adjustments if you have a T3200M gateway from Telus?
