11-21-2016 05:16 PM - edited 11-21-2016 05:17 PM
I learned the hard way that running a powerline Ethernet adapter will cause your optik TV to go scrambled and jumpy or lose signal altogether on wireless optik tv. If I connected an Ethernet switch to either my modem or router and then connected the powerline adapter through the Ethernet switch, would that work?
11-21-2016 05:56 PM
You will still be utilizing the household wiring for the powerline adapter. Using a switch won't negate the problems that arise with using a powerline adapter. You would be better off with a Wifi Range extender, or purchase a higher quality router that has better ranges/speeds.
11-21-2016 05:56 PM
