how do I do a internet connection speed test
Reply
Accepted Solutions
Most Helpful
http://www.speedtest.net/ is a great website where Internet speed tests can be performed.
Most Helpful
Resident
Most Helpful
Coach
Good day,
For accurate speed test results. Hard wire (1) computer to your gateway. Then, ensure all other devices are disconnected from the internet. With the (1) computer hardwired; run a speed test from www.speedtest.net - selecting the highlighted bar in center of the screen that says "begin test". If you are having any issues with your internet speeds, feel free to contact tech support at telus.com/chat. Tech support will follow proper diagnostics to just to ensure there isn't anything preventing you from experiencing the optimized speed you’re paying for.
Most Helpful
Resident
You can do the internet connection speed test using the website ScanmySpeed.com which will show your approximate internet connection speed result.
Most Helpful
TELUS Employee
TELUS Employee
Hey,
At Telus we use http://www.speedtest.net for all speed tests.  You'll want to wait until the map loads in the middle of the scren and you'll want to click on Begin Test with the green triangle to commence the speed test.
Hope this helps you!
H_D
All Replies
Most Helpful
Most Helpful
Resident
Most Helpful
Coach
Good day,
CPU Alum
CPU Alum
Don't forget Telus has it's own site.
  http://vancouver.speedtest.telus.com/
I prefer using it...
  • no more confusing advertisements telling you to buy performance software you don't need
  • less likely to be blocked when I'm testing connections at public wifi, restaurants and hotels
  • works great on my Blackberry phone
I totally agree, for accurate speeds.  No one else should be using the connections.  I get different speeds testing at different hours when at testing at hotels.
Most Helpful
Resident
Most Helpful
TELUS Employee
TELUS Employee
Hey,
H_D
