Wifi range extender not working
Reply
So I called Telus the other day because my wifi was acting up.  The phone operator got my wifi back up and running but after I had hung up the phone I noticed my wifi range extender (wcb3000n which is plugged into my modem via Ethernet) has stopped working.  I have tried everything I know, restarting the modem and extender and switching out Ethernet cords to check if that was the problem but to no avail.  If anyone could somehow help me that would be awesome.
When you last talked to support, did they factory reset your wireless gateway?
  I didn't,  so unless they did it on their side without me knowing, the answer is no,
Anyone got anything else to try?  Still having problems and resetting modem to factory settings didn't help.
Try calling them again. They will likely have a much faster solution.
