Wifi extenders with no Lan ports!
Is this available thu telus?
Maybe if you clearly explained what you are trying to do, some advice can be offered.
Any Wi-Fi extender will require appropriate access to the network, either physically, or through the administrator interface to properly set up. You may be able to set up an Access pint with only the Wi-Fi login credentials, but that is a minimal use situation, and is slower than most other options as the AP has to accept then forward each packet.
3 REPLIES 3
If they have no LAN port, how would you connect them to your network?
True tho for crazy girl that cant have internet. But I also thought wifi extenders are I put it by the modem and connect it they place it some where else like up stairs and just plug in power only!
