UPS for fibre optic system battery replace?
Reply
Mae
Resident
Just wondering if Telus owns the equipment and I lease it or I own it?
The battery in my UPS is 5 years old and finally have put. The UPS beeps.
The battery is your typical 12V 8Ah gel battery easily available and replaceable.
Am I messing with Telus equipment if I just go in there and replace it myself?
Customer service waits are over an hour. Don’t have that kind of time for a simple issue.
Accepted Solutions
Most Helpful
Officially it is Telus equipment, but if you are comfortable with the battery change, weigh the value of your time waiting versus doing it yourself.
I didn’t realize fibre installs go back that far. Time flies.
All Replies
Most Helpful
Mae
Resident
Thanks for taking the time to reply.
We’ve only had the fibre optic system for theee years but I suspect the UPS or at least the battery were on some shelf somewhere until needed.
And at about $22 for a replacement battery and 3 mins to hook it up, the math works.
Thanks again!
mtn
Advisor
Telus equipment.  Phone CS, they will mail you a new battery and a box for the old one. free.
