Telus satellite tv has no sound?
Myosh
We upgraded our tv and blu-ray player. When watching a blu-ray or Netflix thru the tv, it's great. However, when we turn on our satellite receiver to watch it, there is no sound from any of the channels?? Have checked connections and mute, not the problem!
WestCoasterBC
How is the Satellite receiver connected to the TV? HDMI, Component?
  1. Unplug your satellite receiver and then plug it back in wait for it to re initialize.
If you still have no sound check your Dolby settings on the Satellite Receiver.
  1. Press Menu
  2. Select "System setup"
  3. Select "Dolby Digital
  4. Make sure in PCM mode and hit done.
1 REPLY 1
WestCoasterBC
  1. Press Menu
