Telus ZTE Router Port Forwarding Help?
Oilfielddude
Hey guys, I have the Telus smart hub, service strength is great. But on my Xbox1 my nat type is strict, and I can't find any guides to port forwarding or anything to enable my Xbox to get through to an open nat type, any help would be appreciated
There is an old existing discussion for it here, though no real answers. The ZTE routers are not set up like a regular router you'd see with a DSL or fibre connection. They are pretty restricted. Based on the other discussion it seems they may not have a public IP either. If that's the case, without it port forwarding would be useless if even possible.
1 REPLY 1
