TELUS PUREFIBRE SPEED INCREASE?
Reply
Highlighted
Ambassador
when will it come? its new years already!
Accepted Solutions
Highlighted
Most Helpful
You ask about this on a regular basis and the answer still has not changed. The speed will increase when they are ready to do so. PureFiber 150 is still overkill for nearly anything you'll need to do online.
All Replies
Highlighted
Most Helpful
Highlighted
Advocate
250/250 and 950/250 exist in other towns (but not Vancouver)
I've heard Telus has also tested a symmetrical gigabit tier for employee's but I think their network isn't 100% ready.
Do you have any actual use for a gigabit connection? Traffic shaping with your own router can go a long way.
