DennyH19
+1 more
Helpful Neighbour
11 Messages
Closed
TELUS DSL Problems
TELUS Servers for DSL are really unreliable. I keep unplugging my T3200M modem to get a new ip address, however that does not work. Anything else I can do?
Discussion
Updated
6.1K
0
0
This conversation is no longer open for comments or replies and is no longer visible to community members.
Top Contributors
View MoreTELUS_Support
+22 more
Community Manager
8.1K Messages
FuzzyLogic
+25 more
1.8K Messages
Coach
30 Messages
Community Stats
Total Posts
Total Members
rc
+11 more
Rockstar
Cycling power on the router will not result in it being assigned a different IP address.
0
0
WestCoasterBC
+27 more
Advocate
Have you contacted Telus to check on your service? There isn’t a need to continually reboot it.
Do you have a issue hard wired or with wifi?
0
0
+28 more
If you want a new IP, you basically need to leave the modem unplugged long enough for the DHCP lease to expire. That could be a few hours or a few days depending on the time remaining. There's still no guarantee at that point to get a new IP address. The less inconvenient alternative is a VPN. What problem are you running into where you need a new IP address? Are you getting some error message or was your current IP address banned by some website, app, or game?
0
0
rc
+11 more
Rockstar
What are the results of a speed test on your line?
You may want to try this link.
https://www.telus.com/en/bc/support/article/internet-300-mbps-or-lower
Click on how to test your internet then click on Go
You should see speed in line with the line speeds you say when you look at the router web page.
0
0
