10-22-2016 09:41 PM
I am having problems with the T3200M WiFi. 2.4 and 5Ghz. I can browse web pages and things like that. However, when I do a speedtest.net it frequently freezes on my laptop. I then have to disable/enable the wifi interface. It's a newer laptop with an Intel(R) Dual Band Wireless-AC 3160 wifi chip. Works fine on my TPlink AC1750 WiFi router and have used it on other wifi routers. So there's a problem with T3200M. I tried different settings on the T3200M and my laptop wifi chip. Nothing helps.
Telus IPv6 doesn't work on my wifi router. So in order to get everything working I have to use the T3200M as my router and the TPlink AC1750 as a dumb wireless access point. Hopefully there will be an eventual firmware fix for this.
10-23-2016 10:45 AM
@samiam wrote:I am having problems with the T3200M WiFi. 2.4 and 5Ghz. I can browse web pages and things like that. However, when I do a speedtest.net it frequently freezes on my laptop. I then have to disable/enable the wifi interface. It's a newer laptop with an Intel(R) Dual Band Wireless-AC 3160 wifi chip. Works fine on my TPlink AC1750 WiFi router and have used it on other wifi routers. So there's a problem with T3200M. I tried different settings on the T3200M and my laptop wifi chip. Nothing helps.
Glad that you found the work around using TPlink. I did not had any issue with my desktop 802.11ac Realtek adapter working with T3200M.
04-28-2017 05:24 AM
