Smart Ring setup for fax
mack88
Does anyone know the default ring pattern that is used for the secondary number with the Smart Ring feature? Single, Double or Triple ring. HP Fax setup recommends that double or triple ring pattern be used.
1 REPLY 1
Typically it should be the double ring. Triple isn't very common.
