07-11-2017 10:23 PM
I just got the Telus smart hub with the ZTE MF275R router/modem and I can't get my NAT to be open on Xbox live, I have enabled UPNP and tired port forwarding but neither worked. So I was wanting to bridge the modem to my own router. However when I plug the output from the smart hub into the internet input port on my router I don't get an internet connection.
Is there a way to bridge the smart hub? or is there a way to get smart hub to have an open NAT?
07-11-2017 10:29 PM
This has been discussed on the forums before. It's not possible. The ZTE doesn't have a public IP so no matter what you do on your end, it won't work to bypass the NAT error. Bridging won't be possible either.
07-11-2017 10:29 PM
