05-27-2015 04:22 PM
I have contacted mricosoft and rock star, like Shaw has the same problems with one of their modems, here: https://community.shaw.ca/message/120916#120916
i have the t1200h and i can't get online with gta 5 on Xbox one, will there ever be a patch?
HELP!!!
05-27-2015 06:47 PM - edited 05-27-2015 08:09 PM
As per usual, you have not provided any specific information of what problem you are experiencing, including: the exact error message(s), method of connection (wired, wireless, none), and since you talked about it many times in the past -- whether or not you have bridged the T1200H and how everything is physically connected between it and the Xbox.
If the T1200H is bridged, whether the Xbox is direct to the T1200H or you are using a third party router, it is no longer a Telus issue.
Also, if this was a widespread issue related to the T1200H, there would be far more examples available. GTA5 is a popular game and so far no one else has mentioned any issues on Telus, let alone a T1200H. The only ISP related topic Google popped up was the discussion on the Shaw forums you mentioned. Nothing else found outside of the usual well known Xbox connection nightmares.
05-27-2015 11:44 PM
it directly connected the telus modem!/hard wired. its say you need to transfer your charter and the next day i go on its say currently gta 5 is unavailable!
05-28-2015 01:38 AM
Transfer your character? That's not Telus related. That is an Xbox / game issue.
Also the "GTA is unavailable" error doesn't indicate there is a problem with the router, but likely the server you're trying to connect to. Judging by Google's search for that error, it's definitely an issue with the game / XBox Live. Nothing to do with Telus.
Game server status pages >>
05-29-2015 03:59 PM
i have had the game replaced and i thought i ran out of Xbox live but it still working, it was so post to end a week ago! how do i fix the router?
05-29-2015 04:40 PM
Again, you need to provide a LOT more information. Based on your previous posts, there is nothing wrong with your Actiontec. The posting from Shaw was for an entirely different issue that you are not experiencing currently.
Please answer the following if you wish to receive assistance:
06-02-2015 05:07 PM
1. Nothing expect for replacing the game disc.
2. no errors but it says you have to transfer your charter and the next time i turn on my xbox it says unavailable.
3. I don't know, srry
4. No,i used to have a linksys AC1600 but i had it disconnected for about 3 to 6 months.
5. Nope, ill check!
6. Just the PVR directly to the modem though Ethernet and my room set top box/Xbox one.
7.Nope but we had a problem with the internet and TV's lagging and going out for about 5 mins every second day or so
06-02-2015 06:37 PM
The "transfer your character" issue is something with the game and Xbox live. It's unrelated to the modem. Are you trying to transfer a GTA Online character?
06-02-2015 06:49 PM
nope
06-02-2015 10:47 PM
06-06-2015 11:57 PM
?? help!!
06-07-2015 02:07 AM
It is not a Telus issue. It is not a connection related error message. It is not something we can help you with. Since the error you see is game related, go talk to Xbox support or GTA support.
